Flip function messing with dynamic block door
alexj123456789
alexj123456789
I added flip functions to my dynamic block door and the stretch and scale isn't working properly when flipped(attached). Please can someone fix it and let me know how it was fixed.
ojuris
your door width is standardized or any number?
alexj123456789
both, there is a dropdown for specific door sizes and it can be stretched to fit any door opening.
ojuris
If you can use only predefined values - then see attached.
You can add more values if you need. It must be done in 3 places - for parameter Structural Opening list and in lookup tables IN and OUT.
alexj123456789
Thank you thats great! Is there anyway to be able to use both set values and stretch to suit an opening?
timothy_crouse
See if these help
There are a couple different types of doors in the file
Best Regards
Tim
ojuris
I see 2 possibilities:
  1. you stretch by grip door size not opening size
  2. you add in tables and list all sizes what you need (if you think about it probably won't be an infinite number of sizes)
