Dynamic Blocks Forum
FATAL ERROR
3 REPLIES 3
314 Views, 3 Replies
FATAL ERROR
FATAL ERROR: Unhandled Access Violation Reading 0xffffffff Exception at cb465843h
3 REPLIES 3
Emmsleys
Hi @ amit.a.kumar,
Welcome to the Autodesk Forum community.
There are many different reasons this error message can pop up. I suggest checking the following things:
A few questions:
Does this happen with all drawings? Even a brand new file?
What AutoCAD release are you working with?
Please update your post with your results. Thanks!
Sarah Emmsley
Technical Support Specialist
jayhar
You have determined that the latest maintenance update has not yet been installed for your product
recommend that you install this maintenance update to update your product.
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Emmsleys
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Or post with any new updates if you need continued help on your thread.
Thanks for your time.
Sarah Emmsley
AutoCAD Inside the Factory
