Execute Block Rotation Based on Attribute
roger_denisonAW7JP
roger_denisonAW7JP
I want to have a dial with specific angle rotations.  I created the block and added the rotation parameters and actions.  The dials turn like I want them.
What I'm looking for now is the ability to tie each rotation angle to a value in an attribute.  So the user can enter an index number and the block rotates accordingly.
For example,
Attribute Value     Rotation Angle (already defined in the parameter)
           1                            270
           2                            198
           3                            126
           4                            54
           5                            342
The user selects the attribute value and the dial rotates to the correct angle.
Any ideas?
pendean
Community Legend
Community Legend
@roger_denisonAW7JP Nothing in the program works like that: can you share what you have to date? There might be other options.
Libbya
It's a non-starter that has been asked on this forum countless times.  Changes to attributes cannot push changes to parameters.  You can have changes to parameters update attribute values but not the other direction.
roger_denisonAW7JP
I have also discovered that I can use the Lookup parameter/action to achieve the same thing.
MMcCall402
If the attribute values are a set selection of entries you could put together a Block Properties Table to choose the value of the attribute and at the same time choose the correct corresponding value for the rotation parameter.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
roger_denisonAW7JP
That's what I ended up doing.  Thanks for the confirmation I was going in the right direction!😁
