Current settings: Object conversion=Delete
zakkie
zakkie
Good day,
Can't wrap my head around this one.
Clean drawing works first time, no error
Save the drawing and only on first insert it gives an error
NB: Then after first use the error goes away.
Close and reopen drawing produces the same cycle.
Command: TESTWIN
Pick insertion point:
Enter Window size <500.0>: 750
Window size set to: 750.0000
Inserted the block and it set dynamic properties correctly
But displays the following:
Command:
Enter name of output file:
Enter name of existing block or
[= (block=output file)/* (whole drawing)] <define new drawing>:
Any assistance will be appreciated
Thanks Zakkie
(edit) Using Autocad 2026
j.palmeL29YX
I think your problem is better placed in the >programmer's forum<. (?)
But if you do so (starting a new thread there), let here a note where the dicussion is continued.
Jürgen Palme
zakkie
