Current settings: Object conversion=Delete
zakkie
zakkie
Good day,
Can't wrap my head around this one.
Clean drawing works first time, no error
Save the drawing and reopen, only on first insert it gives an error
NB: Then after first use the error goes away.
Close and reopen drawing produces the same cycle.
Command: TESTWIN
Pick insertion point:
Enter Window size <500.0>: 750
Window size set to: 750.0000
Inserted the block and it set dynamic properties correctly
But displays the following:
Command:
Enter name of output file:
Enter name of existing block or
[= (block=output file)/* (whole drawing)] <define new drawing>:
Any assistance will be appreciated
Thanks Zakkie
Using Autocad 2026
komondormrex
hey,
maybe that helps
_.insert->_.-insert
zakkie
Hi komondormrex
I tried every possible variance of vl-cmdf "_.insert"
When removing the dynamic function, no error and no stretch.
When i delete the block and purge it works perfectly so something else is up.
komondormrex
then i would recommend replacing command method for inserting block with vla one.
(vl-load-com)
(defun LM:setdynpropvalue (blk prp val)
    (setq prp (strcase prp))
    (vl-some
       '(lambda (x)
            (if (= prp (strcase (vla-get-propertyname x)))
                (progn
                    (vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
                    (cond (val) (t))
        (vlax-invoke blk 'getdynamicblockproperties)
(defun c:Testwin (/ blo sfw inpt rot blkobj blockExists)
    (setq blo "Win2")
    (if (not (tblsearch "BLOCK" blo)) ;if block exists
        (progn
            (princ "\nBlock 'Win2' not found in drawing.")
            (setq blo (getfiled "Select Window Block File" "c:\\Blocks\\" "dwg" 0)) ;if not then search
            (if (not blo)
                (progn
                    (princ "\nOperation cancelled - no file selected.")
                    (exit)
        (princ "\nBlock found in drawing.")
  (if (not (setq inpt (getpoint "\nPick insertion point: ")))  ;insertion point
        (progn (princ "\nOperation cancelled.") (exit))
    (setq sfw (getreal "\nEnter Window size <500.0>: ")) ;window size
    (if (null sfw) (setq sfw 500.0))
    (setq rot 0.0)
;   (vl-cmdf "_.insert" blo "_non" inpt 1 1 rot)
	(setq blkobj (vla-insertblock (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
						 		  (vlax-3d-point inpt) blo 1 1 1 0
    (if (and ;(setq blkobj (vlax-ename->vla-object (entlast)))
			 blkobj
             ;(vlax-property-available-p blkobj 'IsDynamicBlock)
             (= :vlax-true (vla-get-IsDynamicBlock blkobj)))
        (progn
            (if (not (LM:setdynpropvalue blkobj "DISTANCE1" sfw))
                (princ "\nWarning: 'DISTANCE1' property not found.")
            (princ (strcat "\nWindow size set to: " (rtos sfw)))
        (princ "\nError: Failed to insert dynamic block.")
    (princ)
aamof, i had experienced no issue with your original code.
zakkie
This did the trick!
Thank you so very much!!!!
