How to control a Dynamic Block's alignment
Message 1 of 14
I have been building dynamic blocks for a while now, including using the self-aligning tool. In the block editor, it is easy to install. The challenge begins when going to use the block.
When I go to snap the block to a particular location (usually an intersection of two lines), the alignment tool is doing it's best to guess my intended alignment direction. -sometimes it changes multiple times per second as it stutters with the various direction options. Usually, though, (and often predictably), when I get the block to its final position, it will not align to the direction I want it to, no matter how I move the block into place. If I'm lucky and can get it to cooperate, it usually takes the better part of a minute of micro-adjustments with the mouse. (i.e. I can get it to align to the correct direction. And I can move the block to where it goes. But not both at the same time!)
Is there a keyboard toggle -or some other command- to get it to temporarily 'hold this direction', such as holding down <shift> or <cntl>, while I continue to move the block into its final position?
("I'm holding down 'control', but I'm still not in control!")
Replies (13)
Message 2 of 14
h_s_walker
I have found the alignment parameter to be a bit of a pain. To align to an object you need to have the majority of the cursor on the opposite side of the object you want your block to align to. See the attached image.
Howard Walker
Left Handed and Proud
Message 3 of 14
Hmm, can you clarify your method? I'm having a hard time following you
Message 4 of 14
john.vellek
Hi @Anonymous,
I have found the alignment tool to be a bit tricky too. I have moved your post to the Dynamic Blocks forum so you might get m,ore suggestions from others that work with this more frequently.
John Vellek
Message 5 of 14
MMcCall402
I thought I read somewhere that the alignment grip reacts to which side of the line the cursor approaches.  So if you move your cursor towards a line from one side you get an alignment in one direction but if you approach it from the other side you'll get an alignment in the opposite direction.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 6 of 14
h_s_walker
If you look at the picture the majority of my cursor is on the left hand side of the line I've drawn and the symbol is on the right hand side
Howard Walker
Message 7 of 14
Thank you for the replies. This principle I have already figured out. It's just that the tool doesn't follow that principle all the time.  I'll post a screen shot or two of what I'm wrestling with
Message 8 of 14
As is typical, the car doesn't act up for the mechanic. And neither do my dynamic blocks at the moment.
They do sometimes work. But other times, they just can't seem to find the correct alignment direction (such as when I was showing a co-worker last week that a certain part does fit where we intend for it to go... His response was, "...And _that's_ why I don't like dynamic blocks.")
Again, the ability to tell the block to 'hold this alignment' is a feature I appreciate in other cad software I use. (such as holding down the <shift> key until you finish dropping it into place)
I'll keep watching for 'alignment confusion' and post back when it acts up. Thanks, all
Message 9 of 14
GustavoUbriaco
hi! I guess the solution is change the apperture snap settings in apperture command because I think you've 50 pixels in snap aproximation change to 5 I'll atttach a screencast video 1.png2.png3.png
Gustavo Ubriaco Contreras
Message 10 of 14
Thank you, this Aperture setting may be a solution to this. I'm playing around with it. My LT was set to 13, and I'm going back and forth between 5 and 50 to amplify the difference. I will check in again after some further road testing.
Message 11 of 14
Thanks for the tip.
I had the value on 10 before and got stuck as well - 5 seems to be the magic number 🙂
it works even great with the snap to grid method.
Thanks again.
Message 12 of 14
GustavoUbriaco
You're welcome! thanks to reply!
Message 13 of 14
darien_mctackett
Observer
Observer
REVIVING A DEAD THREAD
ive been trying to come up with a way to make the alignment parameter work better, when today i was playing with the properties and tried setting the "alignment angle" in the block editor when you select the parameter to the opposite direction, (i.e 180degrees) and found the behavior when aligning to be much more manageable so give that a try if your alignments are flicking back and forth
Message 14 of 14
aadish_bin_abdul_sathar
thank u 🙂
