- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm looking to add a feature to a dynamic block that I built for architectural wall panels. The current block has common points at the corners then once I set the width of the panel, I use a lisp file and create points with a maximum spacing of 16" but equally between the common points at the corners. A coworker figured out how to make the point spacing a part of the block without having to go back and use the lisp, but he won't share the block or how he created it. I'll attach a video he sent me of how it works. Notice when he drags the grip to stretch the panel, it adds points to keep them at a maximum of 16" spacing. Any help would be greatly appreciated. I would also like the option to specify the maximum width so that if I do a high wind load project, I can space the points at 8" maximum.
