Attributes in Dynamic Block display As ###
taylor.berryEFGTZ
Observer Observer
taylor.berryEFGTZ
Observer
Observer
Some but not all of the attributes in a dynamic block I use for my work will often display as #### after sharing and downloading the drawing. This can be temporarily solved by running an ATTSYNC on the block to get the attributes to display their true value, but if this new file is then uploaded or sent, upon its download it will once again display ####. Any ideas as to what might be causing this?
After ATTSYNC
Ed__Jobe
It sounds like you have a field in the attribute. Post your block so we can have a look. You don't have to post your whole drawing. Just start a new dwg and insert the block.
Ed
How to post your code.
taylor.berryEFGTZ
Observer
Observer
Here is the block.
Libbya
Works fine for me.  Displays the fields as it should.
taylor.berryEFGTZ
Observer
Observer
It is not constant, sometimes it works fine, and other times it only happens to 20% of the blocks in the dwg. But if someone has any idea why it might happen that would be really helpful.
scooberu
It appears your fields are showing null (no value). Either there is no value in the field they are referencing, or they are not refreshing properly. For example, if I had a field referencing a sheet set value but my drawing was not part of a sheet set, the field would show ####.
Check your system variable FIELDEVAL and set it to evaluate on open, save, plot, and regen.
https://help.autodesk.com/view/ACD/2022/ENU/index.html?guid=GUID-EF5D2DDE-A170-4BB4-8F76-7F3FAFE30E5...
Possibly Etransmit too, if you do that.
