Hello everybody.
I know that this has already been asked, but I don't remember the keywords to search for the topic, so I made this new one.
I have a couple of questions regarding dynamic block creation.
Attached is an example of what I would like to create.
Any help appreciated. Let me know if anything is not clear.
Solved by j.palmeL29YX. Go to Solution.
@SoaresASBCAD Many thanks for the tutorial video, today I finally watched it 😌.
Unfortunately it doesn't cover my question.
So I'm asking again: Is it possible to create a dynamic block with some text that changes depending on the geometry (as shown in the screenshot)?
@Wojty1 wrote:Is it possible to create a dynamic block with some text that changes depending on the geometry (as shown in the screenshot)?
Yes. (Attribute -> Field -> BlockPlaceholder)
See attached example.
(the text will be updated after a REGEN)
Jürgen Palme
Wow! Many thanks!
It works exactly as I wanted it to.
One more question ... or maybe two:
1. Is there an option to avoid to regen the drawing?
While reproducing this block from scratch I'm stuck at the attribute definition. I'm not sure if I understand the concept of how attributes are created.
2. Do I add a block attribute from within the block editor or in the drawing itself?
To see the latest value of fields you can either update fields manually using the UPDATEFIELD command or let do it AutoCAD automatically after OPEN, SAVE, PLOT, ETRANSMIT or REGEN depending on the value of the system variable FIELDEVAL.
A quick and dirty video:
For crone and stem AutoCAD "reads" the current values of the geometry (the parameters), height is a "normal" attribut with a leading text, whose value is asked the user for.
HTH
Jürgen Palme
Many many thanks for your efforts! 🙏
Now I need some fine tuning of the block, so the text moves with the tree size.
That'll be the job of "Constraints" which I have to learn next.
