Dynamic Shelf Block With Array Of Dynamic Holes
paul9ZMBV
paul9ZMBV
Hi
I have a dynamic block with a shelf drawn,
The dynamic block can be adjusted for width and for the thickness of the shelf.
Could someone kindly add a dynamic array to the block that i can pull the adjustable holes up or down (32mm apart)
So the shelf could either have just the 2 holes supporting it or say another 4 pairs of holes above and another 3 pairs underneath (for example)
I just cant figure out how to add the array in the dynamic block.
TIA
j.palmeL29YX
Is that what you're looking for?
Jürgen Palme
paul9ZMBV
Thanks for the help.
The shelf thickness needs to stay constant (unless the shelf is stretched in thickness)
The shelf stud holes (5mm holes) need to be able to stretch up as an array and down as an array separately so that the hole directly under the shelf is on the top of the hole.
If that makes sense
j.palmeL29YX
Test the attached  ...pa1
Jürgen Palme
paul9ZMBV
very very close,
just one small error the shelf ends don't follow when thickness stretched
Your help is much appreciated with this
ch
j.palmeL29YX
Oh sorry, I forgot to include the both vertical lines into the selection set of the stretch action.
Attached the repaired block (name not changed).
Jürgen Palme
paul9ZMBV
Thank you very much for your help with this its much appreciated
