When I modify the stretch actions (Action Selection Set -->Modify Selection Set), AutoCAD always asks me to specify the stretch frame, and then select objects to add or remove.
In most of the cases, I only want to add or remove objects, without changing the stretch frame. Re-specify the frame is a redundant step (possibly even causing trouble because I failed to include same elements in the new frame) in those cases, so I am wondering if I can skip this step and go directly to the add or remove object step.
Thanks in advance for your help
