good day!
Having about 900 possible combinations of this embed I am representing, I decided to make a block table. All seemed well, as the users really like the filtering aspect of block tables.
the issue is:
when I want to adjust large quantities of this block, usually I would just window them and use properties to make my adjustment. Alas, I realize that block tables don't really drive, so if I change the length I would want the part number to change, but it doesn't. That makes sense, the table is just organizing information but not really connected or driving in the way a look up table would be.
So, any ideas on the work flow of having to insert hundreds of these into a file, then later having to change the version of the block?
Or any way to make the lookup parameters act more like the look up table where it filters selection for you?
or, is there something I am just completely missing in the first place?
thank you anybody out there for advisement.
Solved by Libbya. Go to Solution.
If you select all of the ones you want to change, go to properties, select block table, and select the new correct row (granted it isn't presented in the nested pulldown format that it is in model space) then all will switch to that row. The part number certainly changes...once you do a regen to update the field. If you want the part number to update immediately without a regen, then get rid of the field and add the attribute to the table and fill out the attribute values for each row.
Thank you. I was trying to avoid users in the table but hey, you only live once. I am going with it.
enjoy the day!
I'm not sure why you want to avoid users seeing the rows of the table. To be clear, you cannot edit the table from within properties, you can only select the row. You can only edit the table from within block editor.
