Hi, I wasn't able to create simple dyn block (for marking cross-slope of the roads) which will work properly, may I ask you for help.
It seems to work well when block has 0 degree rotation but when rotate attribute gone crazy. I wanted to add alignment parameter to it but because of the issue I resigned.
Also I noticed minor issues but .... it will be great if sb of you help me get this work (no mather how I will rotate blk).
Generally I wanted to keep rotation of att the same as top side of triangle
and always keep fixed distance from line and mid distance...
Please help.
Thanks in advance, for any clues.
BR,
Chris
Solved by Libbya. Go to Solution.
Solved by ojuris. Go to Solution.
Get rid of all of the constraints. The screencast in the following post shows step-by-step how to do it. For educational purposes, I tried to demonstrate within the screencast what I was doing at each step. Some of it was experimental. I believe the end result works exactly the way you proposed.
Thank You very much, this is exactly what I wanted.
I will learn a lot of new things from your Screencast - double thank You for that and for time You spent on this.
BR,
Chris
