Dynamic Blocks Showcase: share your favorite dynamic blocks and show us how you made them!
As a follow up to our latest dynamic blocks webinar, we'll post our favorite dynamic blocks here with Screencasts to illustrate how we created them.
Please join the conversation: share your own blocks or get some inspiration from your fellow community members. Let us know how you save time in your designs by using dynamic blocks!
If you're interested in watching our Dynamic Blocks webinars, or signing up for future AutoCAD webinars, check out these links:
Inside the attached detail there is a ISO cable bundle with a wipeout.
Hope a designer or two find it useful.
Best Regards
-Tim C.
Please note the drawing uses named plot styles so if you're using CTB there is a little conversion required to get it to plot the way you would want/expect.
Here's an example of placing a curtain wall along a curved area using a dynamic block.
Hope folks find this useful
Best Regards
-Tim C.
Two 36 in dynamic door blocks, BYLAY and SWING BYBLOCK
Please note the swing is controlled via a parametric constraint which seems to get out of sync at times, specifically the arrow control will switch to the opposite end of the arc. If this happens reset the block and use native acad commands to set the door into position. It doesn't always happen and I have not been able to nail down the exact sequence to resync the control. Hardly a hard stop, Anyways, hope someone finds these useful
Best Regards
-Tim C.
sorry in the lookup table 5, what is (0,) [0,60] or something like that mean.
Here are a couple of staircase blocks predefined as new and existing, I hope a few folks find them helpful.
UPDATED ON 20241020
Added Block Table
Added Setup Instructions
Tweaked color byblock assignment
UPDATED ON 20241022
Added another staircase
block to the drawing along with a direction
or traffic flow symbol
20241025
-Added more control over the break symbol
-Added (2) move visstates with a continuous handrail
20241027
-Updated Info visstate to provide ctrl movement distance ref info
-Added another version of the block using a different stretch origin setup
-removed one of the width controls to reduce user interface confusion
-Added Flip & Rotate Controls
-Added additional visstates for fixed upper staircase
-Left the original block in the file for folks who wish to explore different techniques used
-Added Scale Picklist to Direction Flow Symbol Block
20241028
-Added Block Intended Use Note
-Added Dashed Line Tips to Info visstate
Added Break Symbol Symmetry Note
20241103
-Added Example Staircase Setups
20241109
-Updated examples to include continuous handrail examples
Best Regards
-Tim C.
Here is an adjustable monitor mount with 34in curved monitor.
Best Regards
-Tim C.
Here is a block useful when reworking architectural building drawings
Best Regards
-Tim C.
I use these components to clean up Revit floor plan files when creating a buildout package in cad format.
The pieces are in imperial format.
Best Regards
-Tim C.
Two Sets of Power Panels
1. power panels have been setup dedicated per system type, Eg not nested, with minimal visstates and settings.
2. Nested block setup with many states
Here is a tip for the Electrical Designers out there:
Remember to set your panels off the wall a bit if the wall lineweight is a bit heavy it may overlap the panel graphic a bit.
Hope some folks find these useful.
Best Regards
-Tim C.
Here are a few Panduit Fiber Runner Type Component block the data center designers out there may appreciate.
Best Regards
-Tim C.
Here are a few updated RAF blocks I use in com room data center designs.
The individual rows have a visstate of no boundaries so they can be used in between grid blocks without having stacked boundary lines.
These have been set in an STB plot environment, adjust layering to meet CTB requirements.
Hope a few folks find these useful
Best Regards
-Tim C.
