Dynamic Blocks Showcase: Share Your Favorite Dynamic Blocks
Victoria.Studley
Autodesk Autodesk
Message 1 of 313
Victoria.Studley
Dynamic Blocks Showcase: share your favorite dynamic blocks and show us how you made them!
As a follow up to our latest dynamic blocks webinar, we'll post our favorite dynamic blocks here with Screencasts to illustrate how we created them.
Please join the conversation: share your own blocks or get some inspiration from your fellow community members. Let us know how you save time in your designs by using dynamic blocks!
If you're interested in watching our Dynamic Blocks webinars, or signing up for future AutoCAD webinars, check out these links:
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Replies (312)
Message 221 of 313
tim_crouse
I am assuming by SWING LINE you are referring to the thin leader line, Eg not the arrow tip.
The line type is set to BYBLOCK you you can either place the symbol on a layer with a continuos line type or set the line type of the block to whatever you want via the line type properties setting.
Message 222 of 313
tim_crouse
The Tip of the arrow is the origin so it has a built-in point move.
You could add a second flip to the center of the text and select the leader objects to flip or you could re-assign the existing flip if you wish for it to be centered on the text.
Message 223 of 313
guardian2563XY93
I meant the arc that shows the swing. At 90 it shows up as a arc with a dash in it. At 45 it's fine
Message 224 of 313
tim_crouse
I have had the basic fan in my library for a long time waiting for some inspiration on how to jazz it up.  I hope you like the results.
It's a good block to add some detail to your drawing.
Best Regards
-Tim C.
Message 225 of 313
dstewardEGNTS
This may not be real impressive but it saves a lot of time
Message 226 of 313
markymarkRE7H6
I built a dynamic block to use as an ID Tag in P&ID drawings. I was not happy with the stock block when the label text was too long. So I made one that can stretch to fit. In some cases the Tag doesn't need a leader line, so I added a visibility state to hide/show that. I use a polar stretch so the block can follow any line angle. I added a wipewout background to hide the pipes behind. The text moves half the distance of the polar stretch so it stays centered. I made the leader line follow the center as well. Hope this is helpful PillBlock.png
Message 227 of 313
tim_crouse
Here are a set of light fixtures useful for plan view work.
Migrated predefined objects and hatches to "byblock" (hatch color, hatch transparency, plot style) to provide more user control to achieve better plot results without having to rework or explode the block.
Hope folks find these useful
Best Regards
-Tim C.
Message 228 of 313
tim_crouse
Dynamic Light Fixture R1
Rework outer object line and hatching to provide better plot control
Added a few more light fixtures to the multi-type fixture
Best Regards
-Tim C.
Message 229 of 313
tim_crouse
Here are a couple of distance Tags I used on non-scaled diagrams.
I found these useful to display both values on a drawing without hand jamming the conversion each time I needed it.
As they are dynamic getting linked attributes to refresh can be tricky, a sure way to get the refresh to happen is to edit the MASTER LENGTH attribute via dbl-click, then edit a linked attribute BUT exit before making any changes, then run the REA command.
Hopefully, someone else will find it useful.  As it is a dynamic block updates can be tricky so a set of attributes were provided to allow the values to be hard coded as well.
Best Regards
-Tim C.
Message 230 of 313
wiscontech
Community Visitor
Community Visitor
The line type (arc) is set to BYBLOCK you can either place the symbol on a layer with a continuous line type or set the line type of the block to whatever you want via the line type properties setting.
Message 231 of 313
tim_crouse
Here are a couple of dynamic blocks loaded with electrical receptacles.
Hope folks find them useful
Best Regards
-Tim C.
Message 232 of 313
tim_crouse
UPDATED
Here are the elevation views updated:
-Added Wipeouts
-Added Block Properties Table to set up a menu selector
As always, I hope folks find these useful
Best Regards
-Tim C.
Message 233 of 313
tim_crouse
Here is an updated dynamic door block.
Many update, see instruction visstate for user tips.
Best Regards
-Tim C.
Message 234 of 313
tim_crouse
Here is a set of receptacles electrical designers may find helpful.  The Visstate table has been provided to allow you to easily break the block up into smaller groups if so desired.
There are many visstates, which tends to slow the block editor down.  One trick that seems to speed the block editor GUI up is toggling "SHOW ALL VISSTATES"   This may seem counter productive but if this is not toggled ON visstate selection can be painfully slow inside the block editor (at least on my matches).
This block took some time to create, if you find any errors please let me know.
Best Regards
-Tim C.
Message 235 of 313
tim_crouse
Here is an update to a previous release.
The blocks have been updated to include a ByBlock Visstate to provide control over a single block instance.
As always, hope a few folks find these helpful.
Beast Regards
-Tim C.
Message 236 of 313
dissonant77
Observer
Observer
@buckeyefever2 wrote:
Here is a dynamic block I created for miscellaneous electrical outlets. It has multiple visibility states that we frequently use in our electrical design drawings. With frequent changes from building owners these designs can change dramatically. So, with the flexibility of changing receptacle types may seem minor, but with 100+ in a design this saves a bunch of time. With it also being annotative makes inserting these in to different scale drawings quick and easy. I broke this out into each side of a wall (i.e. bottom, left side, etc.) to even simplify the insertion process. Hope you enjoy this block, and any suggestion on how to improve this block or add to it would be appreciated.
This is a great block but I'm having some issues with the entering in values for MoveReceptacleX and Y and RotateReceptacle.  The block starts with MoveReceptacleX=0, MoveReceptacleY=1'7 3/8" and RotateReceptacle=90 (the starting value within MoveReceptacleY does not make sense to me).  When I enter a number into MoveReceptacleY, the RotateReceptacle value changes (When I enter 2, RotateReceptacle=160 even while maintaining the same orientation on the screen).  However, entering in a value into MoveReceptacleX doesn't change the RotateReceptacle value as long as the value remains 90.  Entering any value into RotateReceptacle  appears to work only once and then after displays the wrong value (If I change the value to 0, it will show the receptacle at the correct angle, yet changes RotateReceptacle=251.  Entering a subsequent value, ie 90 degrees will not show the receptacle in the proper orientation any longer and RotateReceptacle=159.)  Also, negative numbers cannot be entered into MoveReceptacleX or Y to allow the block to move left or up.  (Reattaching block from original thread so others can verify function/issues).
This is a great block and hope it can be fixed to work properly!  Would also be nice if it incorporates other receptacles (simplex, floor, ceiling, dryer, stove, EV and other special) and had a height attribute!
Dynamic electrical blocks and other electrical design tools have been hard to find.  Do you have any for light switches (given all the energy codes now requiring occupancy, vacancy, photocell controls not to mention your low voltage switches), circuits and home runs?
Message 237 of 313
Francisco_Melo
A dynamic plate with holes and a two-way stretch.
Beast Regards
Francisco Melo
Message 238 of 313
chriswade
Here is a callout block with multiple options, including point of connection, point of disconnection, reference note, additional text, leader line, etc.
Also attached is a detail box with options for with scale, without scale and key plan along with another block of gridlines on a nonplot layer to allow for making a 4x4 grid of detail boxes of equal sizes.
Message 239 of 313
latif_ozdem
IPE400 and IPE400 Bolted Connection Stiffened End Plate
Message 240 of 313
tj6TCQ5
Here is one I created to help teach my newer CAD technicians about wall section footings.
We don't use this day-to-day, and I usually draw from scratch but it might be helpful to others.
