Dynamic Blocks Showcase: Share Your Favorite Dynamic Blocks
Victoria.Studley
Autodesk Autodesk
Message 1 of 298
Victoria.Studley
Dynamic Blocks Showcase: share your favorite dynamic blocks and show us how you made them!
As a follow up to our latest dynamic blocks webinar, we'll post our favorite dynamic blocks here with Screencasts to illustrate how we created them.
Please join the conversation: share your own blocks or get some inspiration from your fellow community members. Let us know how you save time in your designs by using dynamic blocks!
If you're interested in watching our Dynamic Blocks webinars, or signing up for future AutoCAD webinars, check out these links:
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Replies (297)
Message 201 of 298
timothy_crouse
Here is a transformer schedule using the feeder row block
Best Regards
-Tim C.
Message 202 of 298
timothy_crouse
REVISED
Use this updated version
-Tim C.
Message 203 of 298
controlsgirl
Great share. A lot of useful content!!
Message 204 of 298
timothy_crouse
Here is an icon to placed throughout electrical risers to clarify the design intent of where N-G bonds are required.
Hope folks find this useful.
Best Regards
-Tim C.
Message 205 of 298
timothy_crouse
Meet Hue-Man  🙂
A couple of useful blocks for ergonomic planning tasks.
I created Vitrue man some time back but came across Hue on grab cad and updated him a bit.
Hope folks find these useful
Best Regards
-Tim C.
Message 206 of 298
timothy_crouse
Here is a Desk / Workstation planning detail
Hope folks find it useful
Best Regards
-Tim C.
Message 207 of 298
timothy_crouse
Here is a bit of a universal MLeader style dynamic block that may be of use to some folks.
Best Regards
-Tim C.
Message 208 of 298
timothy_crouse
Here are a few cable labeling blocks that may help a few folks
Best Regards
-Tim C.
Message 209 of 298
h_s_walker
Well I had hoped to have an analogue dial gauge working, but beggars can't be choosers. Here is a fully working digital dial gauge. The font needs to be installed in the windows directory for it to work.
Howard Walker
Left Handed and Proud
Message 210 of 298
timothy_crouse
Is this something you can use?
An Analog Dial Indicator.
Hope folks find it useful.
Message 211 of 298
h_s_walker
I already have an analogue gauge. I created it ages ago. It's just that I want the dials to rotate when I change the length of the shaft.
Howard Walker
Message 212 of 298
timothy_crouse
Here is an update to the previous circuit tags posted in this thread.
Electrical designers may find this useful.
Best Regards
-Tim C.
Message 213 of 298
timothy_crouse
Here is an arrow leader folks may find useful
Best Regards
-Tim C.
Message 214 of 298
neaton
@timothy_crouse  Nice arrowhead options, I would remove the text from the flip parameter because if the rotate parameter is used before the flip parameter, the text rotates to odd angles.
Nancy
Message 215 of 298
rbarbosa8DQGJ
Nice job, but the flip tool is not working allright.
Message 216 of 298
rbarbosa8DQGJ
Message 217 of 298
timothy_crouse
Updated Hue-Man, corrected faulty flip
Best Regards
-Tim C.
Message 218 of 298
timothy_crouse
Revised Arrow
-Added a few more
-Added a menu
-Removed test from flip
For added control to adjust for plotting on the -fly
-Object lines are set to ByBlock
-Shading
--Color - Byblock
--P;lot Style ByBlock
--Transparency Byblock
Message 219 of 298
guardian2563XY93
I really like this block but I have a couple of questions.
I can't seem to see an arrow to flip the swing so I just mirror it. The other thing is how to get the swing line to be continuous instead of a dashed line
Message 220 of 298
ruan.vandenberg
1 suggestion make the text the center of the block so that you rotate and flip as the text as your center of rotation. Other than  that pretty cool block. I would also maybe put in a move point on the arrow too so that you can move the arrow separate from the text. I did play around with it a bit and I did the suggestion above but i dint check that all states work. Have a look at the first first visibility state about my suggestion above.
