Dynamic Block with relative variables
allebana13
allebana13
Hi everyone! I'm working on this dynamic block, i think this gonna be easy for you guys (i'm very new at this). The thing is i wanna to set the variables A, B, C, D, Y and Z. I had no problems with A, B, D and Z. But when i do the same with C and Y the parameters mess up. I post de block for you to see it.
The problem that i see is, since C and D are related, when i change one of them, the variable doesn't work in a relative way. For example, i wanna to set D=100 and C=40, but when I change C doesnt keep the value of D.
I hope to be clear, sorry for my english, this is not my language.
Ah! Another question that i have, i can´t see the real difference between LINEAR PARAMETER and CONSTRAINT PARAMETER (the one with lock symbol). is one better than the other?
Thank you all.
ojuris
hi!
try attached
allebana13
That works perfectly fine! Thank you so much. I think that is exactly what i was doing, but surely i was making mistakes regarding the base points or the selection set. Thank you!
