Dynamic Blocks Forum
dynamic block with multiple show on/off visibilities
1 REPLY 1
Shay.Gaghe
378 Views, 1 Reply
Hi
I want to create a dynamic block with multiple show on/off visibilities.
For example, a bad with side table as options
Visibility states:
Bed
Bed with left table
Bed with right table
Bed with left and right table
I have a lookup for each table with Yes/No entries, but cant find a way to map them to all 4 visibility states.
Any idea?
Ive attached the dynamic block I manage to create,
S
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
1 REPLY 1
hwalker
in reply to: Shay.Gaghe
You need a double lookup.
Have a look at the responses in 4-Way Visibility States using Double Lookup Method - Autodesk Community - AutoCAD to see how to use them
Howard Walker
Left Handed and Proud
Forma Design Contest
AutoCAD Beta
