Dynamic Blocks Forum
Dynamic Block with Multiple Flyouts in Multiple Sublevels Issue
2 REPLIES 2
MFaiolaWH9YH
171 Views, 2 Replies
I am trying to get my dynamic block flyouts to work the way I would like them to but am not sure if it is possible. I think the issue is due to there being 3 different "types" being used for the first category (Interior), while I only want to use 2 different "types" for the second category (Exterior). I have included a PDF that has the various tables and outputs with a description of what I am hoping to achieve. Thanks in advance for any help!
2 REPLIES 2
MMcCall402
in reply to: MFaiolaWH9YH
Try copying the visibility entries from the visibility column into the empty cells above and below the three 'Pole Light' entries in the type 3 column.
I'd like to test a few things with this but its a lot to build from scratch.  Could you post the block?
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
MFaiolaWH9YH
in reply to: MMcCall402
D'oh! I was so caught up with the "types" I did not even think to add the visibility names. Thanks!!
Forma Design Contest
AutoCAD Beta
