Numerical Increment of specific attribute in a multi attribute block
alxnds5
alxnds5
I currently have a block with 3 attributes, lets call them A, B, C.  When I try to use a numerical increment lisp on the block the increments happen to attribute A but I need this to happen to attribute B instead. I understand the system is choosing A because it is going alphabetically but is there any way to bypass this?  I know I can simply rename the attributes but I'm looking to see if there is another way.
Libbya
This doesn't have anything to do with the dynamic properties of Dynamic Blocks.  It has to do with LISP.  Because of this, it is a question that would be more appropriate on the AutoCAD Customization - Visual LISP, AutoLISP and General Customization forum.
vinodkl
Here is the lisp that does what you asked for and its more advanced (see attachment)
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
rmarchandYXUEE
It almost works. I need it to allow osnaps to like the center of a circle.
rmarchandYXUEE
SORRY! I see it now.
