dynamic block with height and width to be locked
waseemtarik
Message 1 of 8
waseemtarik
hi there I want to create a door and a window as well but with a locked minimum and maximum width and height so no one can explode it. but I have two type of width and height, is it possible to have a dynamic block that has stretch action with certain height and width ?
I will list the width that has to be locked
minimum width 483mm x minimum height 610mm
minimum width 660mm x minimum height 483mm
as you can see that these sizes can be more but when I want to stretch to 483mm width then height has to be no less than 610mm
I will attach a dynamic block if you could please have it locked with these sizes, if it works then I will list the maximum as well.
thanks
Replies (7)
Message 2 of 8
h_s_walker
In the first image change the highlighted lines to what you want. In the second image change the highlighted line to no
Howard Walker
Left Handed and Proud
Message 3 of 8
waseemtarik
@h_s_walkerthis method will give me only one height and one width. which is not what I'm looking for. I have some standards I want to follow. thanks
Message 4 of 8
h_s_walker
Change "Dist Type" from NONE to LIST, and then you can list a set of distances
Howard Walker
Message 5 of 8
What you may want to consider is creating parameters for each Visibility State.  Which you could set the max min amounts for the specific items.
Message 6 of 8
lena.talkhina
Hello @waseemtarik  !
Great to see you here on Dynamic Blocks Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 7 of 8
waseemtarik
@lena.talkhinaHi Lena,
unfortunately I didn't get the exact answer that I was looking for, perhaps I didn't make it clear enough of what I want,
however I will attach the CAD file for an awning. this is dynamic block, looking for some sizes to be locked but I also want to stretch it with different sizes that provided below, the reason I want these sizes to be locked, so drafters won't have more than maximum or less than minimum, also I don't want to have it as lock-up or visibility that we choose the sizes.
hope I made it more clear now.
the sizes will have to meet each other.
991mm wide to meet 483mm height
660mm wide to meet 533mm height
483mm wide to meet 660mm height
these sizes are minimum.
for maximum sizes
864mm wide to meet 1778mm height
1575mm wide to meet 991mm height.
these the sizes that I want my dynamic block to follow when I stretch it but I also can stretch it in sizes that are in between those numbers.
hope these will help now.
best regards,
Message 8 of 8
waseemtarik
@lena.talkhinathis is the attach CAD file
