Hi
I hope someone can help. I've used some basic dynamic blocks for a few years now but all of a sudden they dont work like they used to despite the files being the same.
I have attached a typical patio door plan and if I select the stretch arrow I used to be able to just type in the size of the doors I wanted and it would stretch the doors to that length however, now it ADDS the dimension I type to the length of the default block.
So if the default block door is already 900mm and I want it 1000mm I would normally just type 1000 and it would then measure 1000mm however, something has changed I suspect with a system variable so if I type 1000 it will measure 1900mm!!
If I open the file in an older version of autocad it works as normal so if someone knows which system variable this is please let me know.
Many thanks
