- Mute
- Permalink
- Report
Hi all,
I have encountered something I cant figure out regarding copying dynamic blocks with a rotation parameter.
It seems as though when a block within a dynamic block is constrained to any other item, if I copy the dynamic block (using CO) then theres issues with rotation.
In File 1, the jib section is constrained to a line at a point and can be rotated.
When I copy the dynamic block using the CO command, and then use the grip to rotate the new block, the rotation also applies to the original block and messes up the rotation grip point.
When the jib block isn't constrained to anything (as in File 2) there is no issue using the CO command and rotating the new block.
Interestingly there's also no issue when using command C + command V to copy and paste either block.
Is this a bug with no fix or am I missing something? Thanks
