I HAVE A DYNAMIC BLOCK WITH AN ARRAY THAT WORKS GREAT UNTIL YOU DO A ROTATE OR FLIP ACTION. CAN SOMEONE SEE WHERE I MISS UP.
Solved by j.palmeL29YX. Go to Solution.
Try the attached attempt.
(The visibility state "all" was created for testing only. I forgot to delete it - do it yourself please)
Jürgen Palme
Works great thanks how did you fix it so I can do it correctly next time specially the array
>>Here<< you can see what I did to repair your block. (In the video I forgot to delete the Linear Parameter "DistanceMFDunits". You should do it yourself).
If that will help you also "the next time" I can not say - each problem need its own steps an "techniques" to solve. 😉
Jürgen Palme
