Dynamic attributes disappeared when i change scale
seabrahenrique
seabrahenrique
Hello guys!
I have this situation here:
I created some blocks to use in my projects and all of them have some dynamic properties.
The problems are: When i change the scale of determinig the axis of that block the dynamic properties disappear.
See this example:
In my first print, i have the block in current scales 1,1,1 and the following dynamic properties:
No problems until here.
But, see the second print, then i change one of scales of blocks the problems occurs, see:
Is there a way to change one of scale of block and maintain the dynamic attributes?
I also put that file in attachment.
Any help is apreciated.
h_s_walker
For grips to stay visible the scale has to be the same for the X, Y and Z axis. If you change one of them the grips will disappear.
Howard Walker
Left Handed and Proud
seabrahenrique
I was wating for this.
Thanks for your answer, mate!
