Message 1 of 16
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi and greeting all,
This is my first post in this community. Hope I can get best support and solution for my query.
I had been trying to do my version / preference of a new dynamic block Double Leaf Door, which it properties can be changed either manually or via Properties Table. I create the block by referring to one of dynamic block door, posted by one of the contributor in this community. After an experiment to another experiment, this is what I get, (refer to the cad dwg I attached - DW_Door02v1-1.dwg).
I managed to do my dynamic block but there is a problem with the Right Leaf which will become skewed and the opening arch will be detached from the leaf. I could not think any other solution to fix this and quite confused with all the parameters and action within the block. What did I missed?
Could you please advise me the solution to correct this?
Many thanks in advance for the advise, knowledge and your support.
Cheers!
Acap
