Block With some lines turned off
It may be very simple for some of you CAD gurus
I have a block of a Smoke detector. I was wondering if I could edit the block with a circle indicating the radius the smoke detector covers, which is simple enough. The question I have is, is it possible to toggle this coverage circle on and off in model space or would I need to go back into the block and make this visible or invisible each time?
Many thanks
Libbya
It is certainly possible.  Add a visibility parameter and add a couple visibility states showing the appropriate linework.
