- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
This might be simple, but so might I be....
I have a very simple block that is a hatched rectangular shape, with dimensions 10 x 1.
I have added an Attribute to the block to show its area, using ATTDEF and choosing a Field, object Hatch, property Area.
This works fine when I insert the block to a natural scale. For example, if I insert the block at a scale of 1 it displays the attribute area of 10, if I scale the block at 2 it displays the area correctly as 40.
The problem comes if I try to give the block a stretched scale. For example, if I insert the block at an X Scale of 2, Y scale of 1, it should calculate an area of 20, but instead it still shows the area to be 10.
In fact, if I give the block any stretched scale at all, the Attribute for area stays at 10.
Anyone out there less simple than me can help?
