Trouble with Array
Trouble with Array
Trouble with Array
I need help. Why does the Array work in BLOCK 1 and not in BLOCK 2? I have created them the same way and with the same parameters. Totally stumped! They should behave the same, but no.
dwg5 is saved down.
Libbya
Please backsave so I can open it in 2017.
Libbya
It looks like a minor bug with the line that is being arrayed.  The following screencast shows my diagnosis/solution.  Long story short, just replace that line and it works fine.
Thank you! So, that tells me, that even though a parameter was erased and the block saved, without the parameter, the entity (a line) is some how still connected to a parameter that no longer exists. Thanks AutoCAD!?
Libbya
I'm not sure what broke it.  I didn't try to investigate further than what is in the vid.  Sometimes odd stuff happens and CAD 'remembers' things it shouldn't and wouldn't 99% of the time.
