Dynamic 3D block imports?
Hi all,
Can parametric/dynamic blocks created in any other software such as inventor or revit be brought into an autocad drawing still function properly?
Poking around these forums and others i see that 3D blocks can be created and manipulated on XY using surfaces vs solids, however im looking for a solution for those cases where you need XYZ edits.
Has anyone had any luck with this, or know if inventor/revit can solve this problem?
Thank you,
-Bruce
fkp7057
No, its not possible bcoz of Autocad block editor not allowed to experiment Z axis and also its not possible to to use Revit library .
You can create some 3d functions using a nested block, where the sub blocks can be in a different axis. Limited functions, it's a pity that the child grip controls can be passed up to the parent block. Maybe Autocad will consider adding some inherence flags to the controls in the future.
