section bubbles
section bubbles
section bubbles
what is the drafting standard for when using 2, 3 or 4 section bubbles that referencing to one detail or section???
Libbya
Are you asking how to link more than one bubble so they display the same value?  You can have one attribute that is edited by the user and each of the other attributes can contain a field that references the user-edited attribute.  After a regen they all display the same value.
You might also be asking how to link a callout to an actual sheet set view.  In that case you would use an appropriate sheet set placeholder field in each attribute.
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
