dinamic block strech+array
Hello, I need some help. I built a dynamic block with stresh and array ( The quantity of columns of vents should increase depending on the width of the cubicle). But it does not work properly
kadmonkee
a couple of things when creating dynamic blocks.
try to keep you base point (origin) @ 0,0,0
and work in the positive quadrant, this will help with any dimensional values
if you start from the beginning, how many vents are there?
what is the original size of the cubicle? width & Height?
do you want the hinges to adjust equally when you increase the height?
the vents should always be equally spaced so the distance between the array will depend on how far (increments) you stretch.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
