Dynamic Block Move after Rotation bad behaviour
Hello Everybody
I'm trying to build a door dynamic block. All behavior seems okay, if there isn't rotation.
When I do rotation then move the behavior become wrong
Please can someone help me, I'm trying since 3 days now without success.
Here attached a sample file.
Regards
Libbya
You should not include all of the other actions in the rotate action's selection set.
Thank you Libyya your tip worked well.
I reset the selection for rotation parameter, and I choose only object and parameters.
However, I don't understand why when selecting actions too, it don't work.
Libbya
When you rotate an action that has an angle offset property, the rotation of the action changes the action's angle offset accordingly.  While that may be desirable behavior in some cases, often it is not.  See the following screencast:
