Parametric Block
Parametric Block
Sujan.Maharjan
Parametric Block
Sujan.Maharjan
Hello there,
I'm fairly new to parametric approach. In this attached drawing I've asked some questions. I don't know if they are achievable or not. Or If anyone can suggest me simplifying the Complex dynamic version that will be welcome too.
"Revit Lies in the tension between what we want to do and what can be done!"
jayhar
First you need to make block, and open Block editor go to parameters set that you wish. Then go to Actions and set all that already set in parameters again. As you wish you can set all using  Parameters  and Action, Then Save Block Try it................
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Sujan.Maharjan
I'm not actually asking how to make a block. I've attached a dwg file please have a look
