Polar Stretch or Rotation
m_rogoff
m_rogoff
Hi, I have a block I'd like to be able to rotate. See attached DWG and Image file to better explain my intentions. The rotation point should be at the center of the bolt at the top right (highlighted in green in the image). I'd like to place the pick point (bottom of the plate on the bottom left) and have the angle of the rod rotate and stretch accordingly, but keep the text and leaders at a horizontal angle with relative position to the rod. Is this achievable? Thanks in advance for your help.
Libbya
Here's a ridiculously complicated solution to what I think you are asking for.  See attached.
m_rogoff
Awesome!!! Thank you Libbya
