I am trying to update a value of a database using dBconnect with the value of an attribute of a dynamic block.
The idea is that when the area attribute of a dynamic block is updated (and the value of the attribute takes the value of a field that is the valor of a parameter of the dynamic block)
this value is also incorporated into the database record linked to DBconnect.
I want to thank Danny Brassinga (DannyNL https://forums.autodesk.com/t5/user/viewprofilepage/user-id/3144455) because with the response to JeanetteAbrahamsen about
"DB connected blocks - how to color automatically via script" ( https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/db-connected-blocks-how-to-colour-au...) opened my curiosity about how to link attribute data with data of data links.
Salu2.
Miguel Tomas
Sebastian
I would very much like to do this also. Please post an update of your discoveries.
I can see that accessing database fields in CAD is very powerful, BUT to make them work together I would like to update the database with data from my drawings. It is easy enough to populate an attribute with drawing info, sheet number, quantities, revision date, etc. I want to pull that back into the database.
