Create an MLine for me?
Message 1 of 12
I run AutoCAD LT, and therefore don't have access to MLStyle.  Would someone be nice enough to create an Mline from the attached drawing for me?
Replies (11)
Message 2 of 12
h_s_walker
It doesn't matter if someone does create an mline from the drawing you've supplied. LT cannot do mlines.
Howard Walker
Left Handed and Proud
Message 3 of 12
But a Block built of MLines, can be used in LT.
I appreciate the input.
Message 4 of 12
h_s_walker
Why not just create the block yourself? If you want to stretch all those lines at once a linear stretch will do.
Howard Walker
Message 5 of 12
I'm at the office, and only have AutoCAD LT.  Was hoping to create this today, as opposed to waiting until the weekend when I have access to AutoCAD.
The block I'm building, is a Trapezoid window, that allows me to adjust the angle to of the Top edge, and still keep the proper corner offsets.  Similar to the attached block, but this one is limited to the angle at which it is built.
I have a very good grasp of Dynamic blocks, but am stuck with the limitations of LT.
So, as it stands, I'm just going to wait till later to do it myself.
Message 6 of 12
I was able to get a few minutes of time to build the picture frame window, and add in the MLine.  In that time, I found out that MLine doesn't do Arcs.  So, that somewhat defeats the purpose of what I was doing.  However, the Trapezoid window worked out well.  Except for an odd reaction.  The dymi9c grip points don't seem to stay with the MLine when it's Stretched.
Attached is the Picture frame.  Any chance someone could take a look and maybe explain why the odd reaction?
Message 7 of 12
j.palmeL29YX
Attached an example (block "test-window") using parametric constraints and dimensions.
I did not (can not) test if it works in ACAD LT too. Give it a try.
If my reply solves your problem, click the "accept as solution" button. This can help others find solutions faster
Jürgen Palme
Message 8 of 12
j.palmeL29YX
@Anonymous wrote:
...  MLine doesn't do Arcs.  So, that somewhat defeats the purpose of what I was doing.
What do you want to do (or to get)? Let us see what you want to achieve with arcs.
Jürgen Palme
Message 9 of 12
j.palmeL29YX
@j.palmeL29YX wrote:
Attached an example (block "test-window") ...
Here added a second variant (because you asked in post #5 for "that allows me to adjust the angle to of the Top edge"):
The block "test-window" (above) can be modified by changing the length of Left Leg and Right Leg independently of each other.
In the here new added block "test-window_1" you can change the length of Left Leg and the angle of the upper beam.
I hope one of the both variants will fulfill your whishes.
Jürgen Palme
Message 10 of 12
That works out nearly perfect.  Thank you.  I have toyed with Constraints, but I haven't had the time to dedicate to fully exploring them,
The ultimate goal, with this, was to build an Arch Top window, where I could adjust the width, height, and curve of the top.  But, stretching and arch, has it's Quirks.
If it's impossible, I understand, and this thread can be closed up, as j.palmeL29YX gave me a great response.
Message 11 of 12
j.palmeL29YX
If it's impossible, ...
It is possible (see attached a first test block "test-window_2"), but I'm not sure, which values you (the user) may change and what then should happen.
Jürgen Palme
Message 12 of 12
That's actually perfect!
So, now I need to spend some time working with constraints, so I can apply this to additional windows (Single Hung, Double Hung, aluminum, vinly), and doors.
Sincerely, thank you!
