Create a formula using multiple attributes in a dynamic block
michael
michael
I am trying to have an attribute in a dynamic block calculate a formula using other attributes in the block. It is a simple span formula, basically A/B*C=D
The Attributes are as follows.
A = D-1 (the attribute is a measurement)
B = Span (the attribute is a measurement)
C = Load (the attribute is a number)
D - is the attribute that I am trying to have calculate that formula.
Any ideas?
3wood
You can try the block in attached file. Edit value of A, B or C and value of D will be updated after regen.
You can also refer to a similar question about how to use Field in attributes in post below:
Solved: Re: Increase attribute's number - Autodesk Community - AutoCAD
