I've made a dynamic block with the solution from another post.
The block consists of line array(the distance between the lines can be changed thru fx) and dimension. array works fine for line but not the dimension.
Also there needs to be a line at the end of array even if the total distance is shorter.
i've attached the block, any help would be much appreciated.
