Hi! Could you tell me how can I constrain these 2 rectangles to have the same centre? Thank you!
Solved by j.palmeL29YX. Go to Solution.
In each of the rectangles draw a diagonal line, add coincident constraints (endpoint to corner).
Then add a coincident constraint between the midpoints of both diagonal lines.
To disable their visibility convert to construction lines.
Note: Post a dwg would have been be better than only an image.
Jürgen Palme
