attribute echo
attribute echo
jdfnnl
attribute echo
jdfnnl
I am working on creating a cross section callout that shows the same detail number and sheet on both ends of the section line. Working from this >thread< on using fields for the duplicate attribute, it became apparent that the solution here would need the field configured each time the block is inserted. Would there instead be a way of entering the field as part of the block definition so that the value is automatically duplicated?
See attached dynamic block as reference.
Libbya
Mike_Y2
I am also trying to do the same thing. Please can you share the answer on the forum?? I can't get to your answer on the google link above
Libbya
