Dynamic Blocks Forum
Constrain 2 rectangles to have the same center
2 REPLIES 2
spufut
286 Views, 2 Replies
Hi! Could you tell me how can I constrain these 2 rectangles to have the same centre? Thank you!
2 REPLIES 2
j.palmeL29YX
in reply to: spufut
In each of the rectangles draw a diagonal line, add coincident constraints (endpoint to corner).
Then add a coincident constraint between the midpoints of both diagonal lines.
To disable their visibility convert to construction lines.
>>Video<<
Note: Post a dwg would have been be better than only an image.
Jürgen Palme
spufut
in reply to: j.palmeL29YX
Thank you so much! That was really useful!
Autodesk Customer Advisory Groups
”Boost
