Hi, I'm working on a dynamic block that is simply a rectangle with a piece of text in the middle. I want to be able to stretch the rectangle vertically and keep the text in the middle of the block as a stretch upwards. Is this possible? I can have them both stretch at the same time but I'm not sure if I can get the text to stretch at half the rate of the rectangle.
I want to keep the text centered if possible. Any advice would be appreciated.
Thanks, Nick
Solved by Libbya. Go to Solution.
Add a move action to the linear parameter the operates the stretch action. In the properties of the move action there is a distance multiplier, set to to 0.5. This will make the move action operate at half the rate of the linear parameter.
Also note, move actions don't have to move in the same direction as the linear parameter. There is also a direction property for the move action.
Yes, it is possible/easy to do. Use only one parameter (not chained). Add the stretch action for the rectangle only. Add a move action to the same parameter and add the text to the move action's selection set. Change the distance multiplier for the move action to 0.5. You can change the distance multiplier either while adding the action, or afterward by selecting it and going to Properties. Here's a screencast.
Years later and you had the answer I was looking for. Thank you very much.
I use the attached block to do this, when the text goes off centre a simple attribute sync sets it all back in the centre.
It seems weird to post a more complicated method that is harder to create and doesn't function as well, after a better, simpler, and more functional method has already been posted.
I'll simplify mine at some point, but it's a block I've hanging around for a while.
Realised why I did so complex, I can't get your solution to work with an Attribute.
