Chain two Linear Stretch. Stretch one at half distance
ndawsonmccann
ndawsonmccann
Hi, I'm working on a dynamic block that is simply a rectangle with a piece of text in the middle. I want to be able to stretch the rectangle vertically and keep the text in the middle of the block as a stretch upwards. Is this possible? I can have them both stretch at the same time but I'm not sure if I can get the text to stretch at half the rate of the rectangle.
I want to keep the text centered if possible. Any advice would be appreciated.
Thanks, Nick
Replies (12)
MMcCall402
Add a move action to the linear parameter the operates the stretch action. In the properties of the move action there is a distance multiplier, set to to 0.5. This will make the move action operate at half the rate of the linear parameter.
Also note, move actions don't have to move in the same direction as the linear parameter. There is also a direction property for the move action.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
Libbya
Yes, it is possible/easy to do.  Use only one parameter (not chained).  Add the stretch action for the rectangle only.  Add a move action to the same parameter and add the text to the move action's selection set.  Change the distance multiplier for the move action to 0.5.  You can change the distance multiplier either while adding the action, or afterward by selecting it and going to Properties.  Here's a screencast.
ndawsonmccann
Awesome! Thanks to both of you!
javierVA2YW
Community Visitor
Community Visitor
Years later and you had the answer I was looking for. Thank you very much.
cloweRE8TC
I use the attached block to do this, when the text goes off centre a simple attribute sync sets it all back in the centre.
Libbya
It seems weird to post a more complicated method that is harder to create and doesn't function as well, after a better, simpler, and more functional method has already been posted.
cloweRE8TC
I'll simplify mine at some point, but it's a block I've hanging around for a while.
cloweRE8TC
Realised why I did so complex, I can't get your solution to work with an Attribute.
doni49
I know this is an old thread, but this seemed like an interesting challenge.  So I decided to give it a try.
The attached block recreates @Libbya's block but with an attribute instead of the text object.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Libbya
The reason his block would not work with an attribute is because the attribute's 'lock position' property was set to 'no'.  I'm not sure why I didn't mention that before.  His posted block also self-destructs:
cloweRE8TC
My block has never done that before when I'm using it, but Don's solution works well, I'm remaking my blocks.
cloweRE8TC
My updated block.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
