Cannot create new visibility state
stanovb
stanovb
I am trying to create a new visibility state in a dynamic block using AutoCAD 2023 vanilla version  like I normally do in previous versions. I set one current & select new but it doesn't do anything and I am stuck there like there us the dialog box open. i cant see if something is off the screen but its acting like i have the box open but i just cant see anything
j.palmeL29YX
Maybe it is outside of your screen?
When you think the window is active try this:
- press Alt + Space
- press "M" (if you have an english operating system).
- press one of the four arrow keys
Now you should be able to drag the window with your cursor.
Jürgen Palme
j.palmeL29YX
I myself just now have had a similar problem: In the block editor of ACAD 2023 (only in this environment) I could not "awake" the Parameters Manager Window. I am not aware of any actions on my part that may have caused this problem. My solution was a "Reset Settings to Default". Perhaps that helps for you (@stanovb)  too(?).
Jürgen Palme
stanovb
I have another version of AutoCAD on another computer. I just did it there.
j.palmeL29YX
What did you do? Could you now solve your problem or not? (Sorry, I don't understand what you want to say).
Jürgen Palme
stanovb
I updated the dynamic block in another version of AutoCAD on another computer. i have not had a chance to look more into why I was having a problem with 2023 yet.
stanovb
I do believe I have discovered where my problem was. My windows display setting was set for multiple displays even know I only have one monitor. I changed the setting to only one monitor & I believe its working now. I had someone totally reinstall windows on the computer recently & the multiple monitors got set.
