Dynamic Blocks Forum
Basic Rotation Parameter Help
2 REPLIES 2
Tee.Dee
402 Views, 2 Replies
I'm having trouble with a dynamic block where I would like to rotate an object and have it only rotate within a 70 degree range.
If you imagine a horizontal line I would like to have it rotate about the left end and and have it only rotate within a range of 35 degrees anti clockwise and 35 degrees clockwise. How best to achieve this?
Thanks!!
2 REPLIES 2
ojuris
in reply to: Tee.Dee
something like that
Tee.Dee
in reply to: ojuris
Thanks ojuris, this is exactly what I wanted and what I was doing in the first place however it seems that it doesn't work with the drawing unit settings I have and I cant work out why, I had clockwise checked and North 270, not a big deal i'll just use the defaults you used. Thanks again.
Autodesk Customer Advisory Groups
”Boost
