Base Point in block different in model space than in Block Editor
GMassengale3QCMV
GMassengale3QCMV
Can anyone explain why the base point and "Position 1" grip for this block is fine in model space, but way out of whack in model space? Thank you in advance!
MMcCall402
Without seeing the file we'd just be guessing at the cause.  Please upload the file/block.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
GMassengale3QCMV
Sorry about that! I've attached a dwg with the block.
h_s_walker
You have a basepoint parameter in your block and it's not at the point move parameter. See the image below
Howard Walker
Left Handed and Proud
Brock_Olly
Why is the grip misplaced?
Because the move/stretch/flip actions don't include the basepoint.
This means if someone moves and flips the textbox around, eventually the end point will end up somewhere out of 'bounds'.
You can rightclick reset block to bring it back to its original state.
Better would be to 'fix' the block.
GMassengale3QCMV
Ahaaa, there it is. The actions didn't include the basepoint! Thank you very much!
