Insulation Dynamic block with Stretch & Array function help.
dave_rawnsley
dave_rawnsley
I have been trying for a long time to get a dynamic Insulation block with scale, flip, rotate & the stumbling block is the array. I want to leave end bat on the stretch & then array the bat trailing to make up the block which may leave an overlap but not worried about that. Attached is a video & the dwg with it in.
Your assistance would be greatly appreciated as I'm just not sure what I am missing to sort it?
h_s_walker
I'm not entirely sure why it wasn't working, but your polyline was the problem.
I made a new polyline (red) so you can see it now works.
I also chained the distance1 parameter to the Length parameter so you only have to stretch the block for the insulation to array.
See the attached drawing
Howard Walker
Left Handed and Proud
dave_rawnsley
Many thanks @h_s_walker, that is bob on.
Like you say strange that it wouldn't work with that polyline but does after it's replacement.
