Dynamic Blocks Forum
Azimuth tool
9 REPLIES 9
Message 1 of 10
1840 Views, 9 Replies
Azimuth tool
I am new to editing autocad and I would really like for someone to help me with this.  I'm trying to make an Azimuth tool where it's like a compass with 4 arrows. Pointing up, down, left, right. I would like to have the degrees at the end of the arrows.
I tried working with dynamic rotate and dimensions, but the dimensions only go to 180. Is there any way to make the specific vertex on the angular dimension work so the dimension can go over 180?
I don't know what to do. It seems so simple, but I don't know how to make this. Thank you in advance!
Tags (1)
9 REPLIES 9
Message 2 of 10
imadHabash
i prepare this screencast as i understand your need.i hope it's help 🙂
Message 3 of 10
in reply to: imadHabash
This is good, but at the end of the arrows I need the degrees it's pointing to. Like where it says N I need it to say 0 degrees and if it turns then I need the degrees. The south I need it to say 180 and if it turns then I need it to tell me what degree it's pointing to. This was useful though. I appreciate the tutorial.
Message 4 of 10
ara_neresesian
HI
there is very small trick ,you have to draw a circle  ,trim  and put dim angular for that arc (or trimmed circle ).
see the picture, I just add angular dimension for red circle
I think this trick will help you (more than 180 degree ,draw circle trim it and put your dim)
you can delete circle after dim ,
you can do this in dynamic block also .
Please select the Accept as Solution button if my post solves your issue or answers your question
Message 5 of 10
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
 I like the suggestions you received here in this thread. I build a quick "compass" for you that uses a field to capture the angle of one of the lines. Perhaps this is an easy way to report the angles. You can obviously adjust the formatting.
John Vellek
Message 6 of 10
in reply to: john.vellek
Yeah just like that. The only difference is that i want it to show -359 when it gets past 0 degrees. I've gotten that dimensions that show positive numbers, but I'd want the numbers to go from 0 to 359. I would also like to have all four corners to be angles. Sorry for these descriptions. I'm not really good at explaining things. Thank you very much for your replies.
Message 7 of 10
john.vellek
Hi @Anonymous,
Try this version.
I am not sure how to get negative values but perhaps if you open the dynamic block to examine the fields you will be able to create a formula that does this for you. If you like, I can move this thread to the Dynamic Block forum.
John Vellek
Message 8 of 10
Sorry, I didn't mean to negative 359, I meant to 359. So when the north arrow passes 0 to the left, it doesn't start back at 0 again. the angle would rotate to the right from 0 to 359 and if it rotates left, it goes from 359 to 0. The south arrow would be at 180 degrees.  Yeah, i think this would be a dynamic block. If you can move it there it might work. Thank you!
Message 9 of 10
Joel_Facet
To change the angle to match your azimuth, you will need to use the'UNITS' command, and change the angle precision check box to 'Clockwise'. I've spent some time today creating this azimuth to do your desired function. As answered previously, the compass is a relatively simple block, but to read the degrees from 0-360 in a clockwise direction you have to change the drawing settings, not the block settings.
I hope this helps, if you haven't already found a solution to the problem at hand.
thanks.
Message 10 of 10
jarredmonday
in reply to: Joel_Facet
Here is what I came up with. It's a start...I made another field with additional values and put it on a different visual state. Then i used a double look up to turn on the visual states depending on the rotation angle. Verify if there are any bugs with it before using it...
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Autodesk Customer Advisory Groups
”Boost
