Dynamic Blocks Forum
Array count?
26 REPLIES 26
Message 1 of 27
1622 Views, 26 Replies
Array count?
i have a parking block with array action.
i want to know how many parking do i have after using the array?
tried using placeholder of the distance, but i need somehow to divide the total.
maybe use formula.
thanks in advance
Array count?
maybe use formula.
thanks in advance
Labels (1)
26 REPLIES 26
Message 2 of 27
h_s_walker
h_s_walker
If the parking space is a fixed width you can put it in a formula. See the attached drawing for a little bit of guidance
Howard Walker
Left Handed and Proud
Howard Walker
Message 3 of 27
ojuris
in reply to: h_s_walker
ojuris
I add another option
Message 4 of 27
pendean
pendean
Community Legend
Community Legend
Slightly off-topic: have you considered using Autodesk's VEHICLE TRACKING add-on for AutoCAD for all of your parking needs? Explore it https://knowledge.autodesk.com/support/vehicle-tracking/learn-explore/caas/video/youtube/watch-v-6ri...
Message 5 of 27
thanks, i can see the array and the stretch action. i can't see the formula in the attribute
Message 6 of 27
in reply to: ojuris
very very nice option
please let me know how the attributes work, for the numbers also
and after i understand these , i am curious if the additional numbers can be as an option to the user, like the visibility parameter?
Message 7 of 27
in reply to: pendean
seems WOOOW!!!
is it additional software?
i have civil 3D 2020. is it included?
seems WOOOW!!!
Message 8 of 27
ojuris
ojuris
In your block I add block with attribute. Then in that attribute I add field with formula and add that block to array.
Message 9 of 27
in reply to: ojuris
thanks
how can i see the field/formula in the attribute? how to get there?
i guess it but i want to be sure
thanks
Message 10 of 27
ojuris
ojuris
see screencast how to add field with formula
Message 11 of 27
ojuris
ojuris
Message 12 of 27
in reply to: ojuris
thank you very much!!!  :trophy:
i'll try the formula idea maybe with the length property because the block can be rotated.
how can i identify if attributes of mine or another users have fields? to open and understand the way formulas/fields were created
Message 13 of 27
ojuris
ojuris
change  FIELDDISPLAY  to 1
Message 14 of 27
in reply to: ojuris
now i can see the fields. but how to open them to see the formula (to insert into the field).
i don't know how to see/update the fields i have created even by myself. i have to recreate them every time i need
Message 15 of 27
ojuris
ojuris
To edit fields - go to in attribute like you want to edit attribute, then right click to field and choose Edit field.
Message 16 of 27
in reply to: ojuris
this is what i tried every time but the only option is to insert field, no edit
Message 17 of 27
h_s_walker
h_s_walker
Don't try editing the field there. Edit it in the main block
Howard Walker
Howard Walker
Message 18 of 27
great!!!! got the "edit" when pointing on the attribute value exactly
how i'm getting the edit of the field within MText field (the one that is calculating the number of parking, without the circle. there is also just the insert field option)
Message 19 of 27
h_s_walker
h_s_walker
It's just like a normal block which has an attribute in it. Think of the car park block as your "main drawing" and the nr block is just a normal block with an attribute which you can edit.
Howard Walker
Howard Walker
Message 20 of 27
i mean this one. it's MText
AutoCAD Inside the Factory
